*set_meshfaceparams
Sets some of the face-specific parameters for the automeshing module.
*set_meshfaceparams face_index shape_type elem_type alg_type elem_size smooth_method smooth_tol size_control skew_control
HyperMesh Tcl Modify Command
This command sets the face-specific parameters for the automeshing module.
- face_index
 - The index of the surface face under consideration.
 - shape_type
 - Determines the surface-based mesh generation algorithm to use when creating elements
            on the face. Valid values are:
- 1 - autodecide
 - 2 - map as rectangle
 - 3 - map as triangle
 - 4 - map as pentagon
 - 5 - advancing front
 - elem_type
 - The type of elements to create. Valid values are:
- 0 - trias
 - 1 - quads
 - 2 - mixed
 - 3 - right trias
 - 4 - quads only
 - alg_type
 - 0 - Standard surface meshing
 - elem_size
 - Reserved for future use. Must be set to 0.
 - smooth_method
 - The smoothing method to use during the meshing process. Valid values are:
- 0 - autodecide
 - 1 - size-corrected
 - 2 - shape-corrected
 - smooth_tol
 - The automesher applies the smoothing algorithm until the largest adjustment made to a nodal position is less than this value. Valid vales are > 0.0.
 - size_control
 - Determines if uniform size elements should be created in mapping algorithms. Valid
            values are:
- 0 - Do not create uniformly-sized elements.
 - 1 - Create uniformly-sized elements.
 - skew_control
 - Determines if optimal shape elements are created in mapping algorithms. Valid values are:
- 0 - Do not optimize element shapes.
 - 1 - Optimize element shapes.
To specify meshing parameters on face 0 of a surface for a quad dominant mesh with no size or skew control:
*set_meshfaceparams 0 1 1 0 0 0 0.1 0 0
   # Handle error
