*morphupdateparameterstring
Updates string morphing parameters.
*morphupdateparameterstring parameter value
HyperMesh Tcl Modify Command
This command updates string morphing parameters.
parameter
The parameter of interest. Valid parameters are:
iressimu: name of the simulation used in FEA results plotting
iresdata: name of the data type used in FEA results plotting
value
The new value of the parameter.
To update the name of the FEA simulation for plotting:
*morphupdateparameterstring iressimu "Cantilver loading"
   # Handle error
Version History
11.0
