*adaptive_wrapper_build
Builds the skeletal octree structure for the adaptive wrap mesher.
HyperMesh Tcl Modify Command
This command builds the skeletal octree structure for the adaptive wrap mesher. It performs proximity checks, refines the octree based on various input parameters, and also identifies gaps/holes and patches them.
This command must be called between *adaptive_wrapper_init and *adaptive_wrapper_end.
It uses input defined by *adaptive_wrapper_set_features, *adaptive_wrapper_set_params and *adaptive_wrapper_proximity_params.
Examples
#Initialization of wrapper mesh with base mesh
*createmark elements 1 "all"
*adaptive_wrapper_init elements 1 1 0
# Define features
*clearmark elements 1
*adaptive_wrapper_set_features 1 1 30 1 1
#Set various meshing and refinement parameters
*createstringarray 7 "LeakCheckNodes: 20 24 19" "GapPatchTolerance: 3.0" "HolePatchTolerance: 10.0" "RefineByBoxCompIds: 4 5 6" "RefineByNodeCurvature: 1" "RefineByFeatureProximity: 0" "RefineByAllElemSize: 1"
*adaptive_wrapper_set_params 10 0.1 1 7
#Proximity options
eval *createstringarray 3 "WithinGroup: 0.5 1 3 10 12 13" "WithinGroup: 1.5 3 9 20" "AcrossGroup: 0.5 3 10 12 13 4 9 8 7 19"
*adaptive_wrapper_proximity_params 1 0.2 1 3
#Build skeletal octree structure
#Generate mesh
*createstringarray 2  "DoRemesh: 1" "RemeshGrowthRate: 1.2"
*adaptive_wrapper_mesh 0 1 2
#End of wrapper mesh
   # Handle error
Version History
13.0
