*updateoffset
Update the definition of offset.
*updateoffset type include_id shortname entity_type pool_id offset
HyperMesh Tcl Modify Command
type
Must be set to includefiles.
include_id
The include file ID, if shortname is not used.
shortname
The shortname of the include file, if include_id is not used.
entity_type
The type of entity to update. 0 for all entities under the include file.
pool_id
The pool ID for the entities to update. 0 for all of pools.
offset
The offset value to assign.
Examples
To assign offset 1000 to all entities in include file 1:
*updateoffset includefiles 1 "" 0 0 1000
   # Handle error
Version History
2019
