*modelcheck_organizechecks
Organize the model check check entities under a given parent folder.
*modelcheck_organizechecks parent_name entity_type mark_id
HyperMesh Tcl Modify Command
Organize the model check entities under a given parent folder.
parent_name
The name of the parent folder to move the checks into.
entity_type
Must be set to modelcheckchecks.
mark_id
The ID of the mark containing the checks to move. Valid values are 1 and 2.
Examples
To move checks 23, 24 and 27 to the ERROR folder:
*createmark modelcheckchecks 1 23 24 27
*modelcheck_organizechecks "ERROR" modelcheckchecks 1
   # Handle error
Version History
2019
