*PenetrationCheckSummary
Generates a summary log file for last run penetration check.
*PenetrationCheckSummary filename sort_intersections sort_penetrations
HyperMesh Tcl Modify Command
Command is used to generate a summary log file for last run penetration check. This file contains a flat list of intersected and penetrated components, followed by more detailed lists of each component-component pair data. If the last check’s input was specified by groups, then the above data is organized by groups, as well.
- filename
 - The name of the file, including its full path, to which the summary is written. The file is appended to if it already exists.
 - sort_intersections
 - A flag that indicates how to sort intersection data. Valid values are:
- 0 - No sorting
 - 1 - Ascending component ID
 - -1 - Descending component ID
 - 2 - Ascending element count
 - -2 - Descending element count
 - 3 - Ascending number of interfered components
 - -3 - Descending number of interfered components
 - sort_penetrations
 - A flag that indicates how to sort penetration data. Valid values are:
- 0 - No sorting
 - 4 - Ascending maximum penetration depth
 - -4 - Descending maximum penetration depth
Output results of the last penetration check (run using the command *checkpenetration) to the file C:\results\check.txt, with intersections sorted by ascending component ID and penetrations by descending maximum penetration depth:
*PenetrationCheckSummary "C:/results/check.txt" 1 -4
   # Handle error
}Version History
10.0
