*icelementcreate
Creates an IC element.
*icelementcreate
HyperMesh Tcl Modify Command
Creates an IC element. *addicconnectivity and *modifyicelement can be used to add additional details or modify the element.
Create an IC element and update the independent node to 15, and dependent nodes to 16, 17, 18, 19 with DOF’s 123, 345, 1234, 123456:
*icelementcreate
*createintarray2d 2 4 16 17 18 19 123 345 1234 123456
*addicconnectivity 1 15 1 2 4
None.
Version History
14.0
