*realizefieldloads
Realizes engineering loads into classical loads.
*realizefieldloads mark_id ?skip_delete?
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark of engineering loads to realize into classical loads. Valid values are 1 and 2.
 - skip_delete
 - 0 - Delete all engineering loads after realization (default)
Examples
*createmark loads 1 "by config" 1
*realizefieldloads 1*createmark loads 1 all
*realizefieldloads 1 1Errors
   # Handle error
}Version History
2020
