*loadsettypes
Sets the global load type variable.
*loadsettypes mark entities
HyperMesh Tcl Modify Command
- mark
 - The mark which contains the loads to be updated.
 - entities
 - The type of load to change.
- *loadtype (1,5)
 - sets new Forces (1) to type 5 but doesn’t change existing ones
 - *loadtype (2,6)
 - sets new Moments (2) to type 6 (doesn’t change existing ones)
 - *createmark(loads,1) displayed
 - places all existing displayed loads into Mark1
 - *loadsettypes(1)
 - changes all the entities in Mark1 to use the types already defined for Forces (5) and Moments (6)
None.
