*linescombine
Combines two free surface edges to create one unsuppressed common edge.
*linescombine edge1 edge2 edge_tolerance
HyperMesh Tcl Modify Command
- edge1, edge2
 - Two free surface edges (face edges which are attached to a surface only once).
 - edge_tolerance
 - The edges must be within this tolerance.
To combine edges 101 and 39, using a tolerance of 0.1:
*linescombine(101,39,0.1)
None.
