*renumber
Renumbers the internal HyperMesh IDs for the specified entity type.
*renumber entity_type mark_id start_id incr_val offset_val offset_flag
HyperMesh Tcl Modify Command
This command renumbers the internalHyperMesh IDs for entities of entity_type contained on mark_id.
This command only renumbers HyperMesh internal IDs, even if the selected entities have solver IDs (see *renumbersolverid).
entity_type
The type of entity selected for renumbering.
mark_id
The mark that contains the entities. Valid values are 1 and 2.
start_id
Integer value > 0 specifying the starting value.
incr_val
Integer value > 0 specifying the renumbering increment.
offset_val
Integer value to use for offsetting. Can be positive or negative as long as after renumbering all entities will have a positive ID.
offset_flag
Flag to specify whether to use offsetting:
0 Use start_id and incr_val and ignore offset_val.
1 Use offset_val and ignore start_id and incr_val.
To renumber the internal HyperMesh IDs of the displayed elements starting from 100 with an increment of 1:
*createmark elems 1 displayed
*renumber elems 1 100 1 0 0
   # Handle error
