*jointelement_fournoded
Creates a four-noded joint element.
*jointelement_fournoded type n1 n2 n3 n4 orientation system1 system2 property
HyperMesh Tcl Modify Command
type
The type of the element (2,3,4,5 ONLY)
n1,n2,n3,n4
The four nodes of the element.
orientation
Orientation option for the element. Use:
  • 0 - None
  • 1 - Systems
system1,2
The orientation systems IDs for the element.
property
The property to which the element points.
To create a four-noded joint element:
*jointelement_fournoded(5,467,466,459,291,1,1595,0, "stiffness")
None.
