*modent_realizerepresentation
Loads the contents of a modular entity representation.
*modent_realizerepresentation entity_type entity_id representation_key
HyperMesh Tcl Modify Command
entity_type
The type of modular entity to load the representation to. Currently supported only for subsystems.
entity_id
The ID of the modular entity.
representation_key
The representation key to load. This is unqiue per subsystem.
Examples
Load the contents of the representation key "crash5" to subsystem 3:
*modent_realizerepresentation subsystems 3 "crash5"
   # Handle error
Version History
2020
