*attributeupdatedoublearray2dmark
Updates an attribute of type 2D double array on a set of entities.
*attributeupdatedoublearray2dmark entity type mark identifier solver status behavior data rows cols
HyperMesh Tcl Modify Command
- entity type
 - The type of entity that owns the attribute.
 - mark
 - The number of the mark.
 - identifier
 - The identifier of the attribute.
 - solver
 - The solver number of the attribute.
 - status
 - The status of the attribute.
 - behavior
 - The behavior of the attribute.
 - data
 - 2D array of doubles.
 - rows
 - The number of rows in the array.
 - cols
 - The number of columns in the array.
Update an attribute of type 2D double array to [1,2,3] on materials with IDs 7 and 8.
*createmark(materials,1) 7 8
*createdoublearray2d(2,3) 1 2 3 5 6 7
*attributeupdatedoublearray2dmark(materials,1,615,2,2,0,1,1)
