*segmentsetcreatewithmixedfaces
Creates a segment set using a mixture of solid elements and shell elements.
*segmentsetcreatewithmixedfaces name color elem_mark_id node_mark_id break_angle reverse_normals
HyperMesh Tcl Modify Command
- name
 - The name of the segment set to create.
 - color
 - The color of the segment set. Valid values are 1-64.
 - elem_mark_id
 - The ID of the mark containing the elements to use. Valid values are 1 and 2.
 - node_mark_id
 - The ID of the mark containing the nodes that define an edge or a face of an element. Valid values are 1 and 2.
 - break_angle
 - The break angle for finding adjacent elements.
 - reverse_normals
 - Create segment set:
Examples
*createmark elems 1 1-100
*createmark nodes 1 1-5
*segmentsetcreatewithmixedfaces "test" 5 1 1 30.0 0Errors
   # Handle error
}Version History
2020
