*splitsolidelements
Divides the given solid elements into hexa or tetra elements.
*splitsolidelements markmask splittype
HyperMesh Tcl Modify Command
- markmask
 - The mark of solid elements to be split.
 - splittype
 - A code that indicates the type of split to perform.
- 1 - splits a hexa into 8 hexas
 - 2 - splits a hexa into 5 or 6 tetras
 - 3 - splits a hexa into 24 tetras
*createmark(elements,1) 100 101 102 103 104 105 106 107 108
   109 110
*splitsolidelements(1, 1)The *createmark() directive is required for this command.
None.
