*sethistoryrecord
Sets whether history recording is enabled or disabled.
*sethistoryrecord state
HyperMesh Tcl Modify Command
state
  • 0 - Disables all history recording, including potential legacy use cases
  • 1 - Enables history recording
To disable all history recording:
*sethistoryrecord 0
   # Handle error
Version History
14.0
