*exportbif
Exports the current database to Medina .bif format.
*exportbif filename
HyperMesh Tcl Modify Command
Exports the current database to Medina .bif format. Currently only nodes, elements, node sets and element sets are supported.
- filename
 - The full path and file name to export to.
*exportbif C:/temp/test.bifErrors
   # Handle error
}Version History
13.0
