*surfacemarksplitwithline
Splits a mark of surfaces with a line swept along a vector.
*surfacemarksplitwithline mark_id line_id vector_id trim_flag distance
HyperMesh Tcl Modify Command
This command splits a mark of surfaces with a line swept along a vector.
mark_id
The mark ID containing the surfaces to split. Valid values are 1 and 2.
line_id
The line ID to use for splitting.
vector_id
The vector ID to use for the split direction. This is defined using the *createvector command.
trim_flag
0 - The line is swept using the distance value.
1 - The line is swept through the entire surface.
distance
The distance to sweep, if trim_flag is 0.
To split surfaces 10 and 20 by sweeping line 11 along the z-axis:
*createmark surfaces 1 10 20
*createvector 1 0.0000 0.0000 1.0000
*surfacemarksplitwithline 1 11 1 1 0
   # Handle error
