*analysisfileset
Loads a results file for use in subsequent operations.
*analysisfileset filename
HyperMesh Tcl Modify Command
Loads a results file for use in subsequent operations. All IDs are assumed to be HyperMesh internal IDs.
filename
The full path and name of the results file.
Examples
To load the result file named C:/my_results/test.res:
*analysisfileset C:/my_results/test.res
   # Handle error
