*surfacemarkmerge
Combines the selected surfaces into one surface, and divides the surface along the internal edges that correspond to fillets and feature lines.
*surfacemarkmerge mark breakangle minradius maxradius
HyperMesh Tcl Modify Command
- mark
 - The mark ID containing the surfaces.
 - breakangle
 - The threshold used to recognize feature lines.
 - minradius
 - The lower limit of the radius of curvature used to recognize fillets.
 - maxradius
 - The upper limit of the radius of curvature used to recognize fillets.
*createmark(surfaces,1) 1 31 57 91 93 145 189 190
*surfacemarkmerge(1,30.0,1.0,15.0)The *createmark() command is required. On the Geom Cleanup panel, this command corresponds to the organize by feature tool.
