*morphmaprecalc
Recalculate influences and prepare for mapping.
*morphmaprecalc nlist nmark edgenode markedge facenode markface mode
HyperMesh Tcl Modify Command
nlist
List mark number for nodes affected by mapping.
nmark
0 - Use input list 0
1 - Use input list 1
edgenode
NODES
markedge
Node mark number for nodes on edge domains where handles will be created.
facenode
NODES
markface
Node mark number for nodes on 2D domains where handles will be created.
mode
0 - Create temporary handles and calculate new influences
1 - Delete temporary handles and restore old influences
*morphmaprecalc (0,0,NODES,2,NODES,3,0)
This command is called before and after mapping operations in the user control sub-panel to enhance mapping speed. The command makes influence recalculation necessary only once, when entering the panel, rather than each time the user wishes to place a handle or edge.
   # Handle error
