*rigidlinkwithset_twonodes
Create a rigid link element "55" between two nodes, with a dependent node attached as a node set connected with the element.
*rigidlinkwithset_twonodes independent dependent dof
HyperMesh Tcl Modify Command
independent
The independent node of the element.
dependent
The dependent node of the element.
dof
The degrees of freedom for which the element is active (any of the digits 1-6).
To create a rigid link element with dependent nodes attached as a set between nodes 100 and 101 in all six degrees of freedom:
 *rigidlinkwithset_twonodes(100,101,123456)
A node set with an automatically generated name is created and a dependent node is placed in this set.
None.
