*move_clipping_sphere_to_XYZ_and_fit
Re-centers the view around a specified point, zooms in or out to fit a specified radius around that point, and does all of this in a specified number of frames of animation rather than instantly.
*move_clipping_sphere_to_XYZ_and_fit x_center y_center z_center radius,n_animation
HyperMesh Tcl Modify Command
- x_center
 - y_center
 - z_center
 - radius
 - n_animation
To pan the viewpoint to center on a point with coordinates (22, 17.5, 93) in 90 frames of animation, and zoom to display everything within 25 units of that point:
*move_clipping_sphere_to_XYZ_and_fit(22,17.5,93,25,90)
      Using frames of animation rather than an instantaneous re-center allows a sense of relative location between the initial view point and the new one.
None.
