*display_thickness
Sets or graphically reviews the thickness assigned to a midsurface.
*display_thickness mark_id thickness update
HyperMesh Tcl Modify Command
This command sets or reviews the thickness assigned to a midsurface.
- mark_id
 - The ID of the mark containing the surfaces to set or review. Valid values are 1 and 2.
 - thickness
 - The thickness to assign to the surfaces on the mark. A negative or zero value sets the thickness to 0. This is ignored, if update is set to 0.
 - update
 - 0 - Display the thickness of the selected surfaces in the graphics area.
*createmark surfaces 1 5 6 7 10
  *display_thickness 1 0 0*createmark surfaces 1 5 6 7 10
  *display_thickness 1 5 1*createmark surfaces 1 5 6 7 10
  *display_thickness 1 -1 1Errors
   # Handle error
