*blockvisualize
Creates a fill hide plot of a finite difference block.
*blockvisualize name iplane jplane kplane icolor jcolor kcolor usewallcolor
HyperMesh Tcl Modify Command
- name
 - The name of the block.
 - iplane
 - The i plane to display.
 - jplane
 - The j plane to display.
 - kplane
 - The k plane to display.
 - icolor
 - The color in which to display the i plane. Not used if iplane is 0.
 - jcolor
 - The color in which to display the j plane. Not used if jplane is 0.
 - kcolor
 - The color in which to display the k plane. Not used if kplane is 0.
 - usewallcolor
 - 1 - If the colors of the walls are to be used.
The color values are not used and the block is visualized using the wall colors, unless the planes are nonzero, in which case, the plane is visualized using the color provided.
Examples
*blockvisualize(block1,0,0,0,0,0,0)
