*loadsupdatecurve
Updates the magnitude, direction, coordinate system, and other information of selected loads.
*loadsupdatecurve markmask config type updatevector component [1-6] updatemag magnitude update_system system_id transform_flag updatecurve curve_id updatexscale xscale updatedisplaylocation xlocation ylocation zlocation
HyperMesh Tcl Modify Command
- markmask
 - ID of the mark containing the loads to update.
 - config
 - The configuration of the load:
 - type
 - The type assigned to the load (as defined on the "load types" panel).
 - updatevector
 - A variable that controls if the direction of the load should be updated.
 - component[1-6]
 - Components of the load being applied. When applying a force, the active components are 1, 2, and 3, which represent a force x, y, and z-axis, respectively. When applying a moment, the active components are also 1, 2, and 3, and represent the moment about the x, y, and z-axis, respectively. For constraints, all of the components are active unless they are set equal to -999999.0. All of the other components of the constraints are active in the respective directions. For pressures, the active components are 1, 2, and 3, which represent the x, y, and z-axis, respectively. To create a pressure that is normal to the element, set all components to zero.
 - updatemag
 - An integer variable that controls if the magnitude is updated.
 - magnitude
 - The new value of magnitude of the load.
 - update_system
 - A variable that controls if the system is updated.
 - system_id
 - The ID of the local system.
 - transform_flag
 - A simple integer variable that controls if the load is created in the local system.
 - updatecurve
 - A flag to indicate whether the curve should be updated (0=no, 1=yes).
 - curve_id
 - The ID of the new curve to use.
 - updatexscale
 - A flag to indicate whether the curve’s scale factor should be updated.
- 0 - No
 - 1 - Yes
 - xscale
 - The new value to use for scale factor.
 - updatedisplaylocation
 - A flag to indicate whether the curve’s display location should be updated.
- 0 - No
 - 1 - Yes
 - xlocation, ylocation, zlocation
 - The new display location (used only if updatedisplaylocation =1)
Example to update a force to use the curve with ID 7 to define its time-varying magnitude:
*createmark(loads,1)  4
*loadsupdatecurve(1,1,1, 0, 0,0,0,0,0,0, 0,0, 0,0,0, 1,7, 0,0, 0,0,0,0)
None.
