*CE_FE_LoadFeConfig
Load or unload an FE config file.
*CE_FE_LoadFeConfig filename load_option overwrite
HyperMesh Tcl Modify Command
This command loads or unloads an FE config file.
- filename
 - The full path and filename of the FE config file.
 - load_option
 - 0 - to unload
 - overwrite
 - Valid only when load_option is 1.
- 0 - Skip FE types with names or IDs conflicting with existing ones.
 - 1 - Overwrite existing FE types with names or IDs conflicting with current ones.
Examples
*CE_FE_LoadFeConfig 1 "C:/test/my_feconfig.cfg" 1 1Errors
   # Handle error
}Version History
13.0
