*createorthotropicdirection
Creates the INSHE/ORTHO_LOC tables based on the composite data in the session.
HyperMesh Tcl Modify Command
None.
To create the INSHE/ORTHO_LOC tables based on the composite data in the session:
   # Handle error
Version History
2017.2
