*CE_PositionConnectors
Positions connectors to the middle point or back to the source location.
*CE_PositionConnectors mark_id center_source upon_state
HyperMesh Tcl Modify Command
mark_id
The ID of the mark containing the connectors to modify. Valid values are 1 and 2.
center_source
0 - Position to center
1 - Position to source
upon_state
0 - Unrealize
1 - Rerealize
To position connectors to middle point and unrealize them:
*createmark connectors 1 all
*CE_PositionConnectors 1 0 0
   # Handle error
Version History
2019.1
