*permutemark
Permutes the entities on a mark.
*permutemark entity type mark type
HyperMesh Tcl Modify Command
- entity type
 - The type of entities contained on the mark.
 - mark
 - The ID of the mark which holds the entities to be permuted.
 - type
 - The type of action which should be taken:
- 0 - Swap x with y
 - 1 - Swap x with z
 - 2 - Wwap y with z
To permute elements 10, 11, and 12 switching the x and y values:
*createmark(elements,1) 10 11 12
*permutemark(elements,1,0)
      *createmark() is required.
None.
