*linereverse
Reverse line direction.
*linereverse line_id
HyperMesh Tcl Modify Command
This command reverses the direction for a given input line. Works for free lines only.
line_id
Input line ID.
To reverse line 12:
*linereverse 12
   # Handle error
Version History
10.0
