*edgesmerge
Combines two edges to create one unsuppressed common edge.
*edgesmerge edge1 edge2 edge_tolerance
HyperMesh Tcl Modify Command
- edge1
 - The first of two surface edges that you wish to combine
 - edge2
 - The second of two edges to be combined.
 - edge_tolerance
 - The edges must be within this tolerance; if they are further apart than this, they will not combine.
*edgesmerge(25,26,0.1)This command is different from *linescombine() in that it enables combining edges that are not necessarily free but already have more than one surface connected. This provides a tool to create non-manifold (T-joint) topology, which may be required in tasks like thin plate modeling.
