*CE_ConnectorSetVectorById
Sets the projection vector for a connector specified by ID.
*CE_ConnectorSetVectorById ce_id type i j k vector node1 node2
HyperMesh Tcl Modify Command
- ce_id
 - The connector entity ID.
 - type
 - The method used to set the vector:
- 0 - Use i, j, and k values (see arguments below). These should be specified as the next 3 arguments to this command.
 - 1- Requires a HyperMesh vector id (see vector below) from which the vector i, j, and k will be taken internally. The i, j, and k syntax arguments can be set as 0.
 - 2 - Requires the two node id’s (node1 and node2 below) as the last two arguments to this command. These node ID’s will be required to create a vector, and assigned to the ce_id. The rest of the above arguments can be set as 0. These two nodes should not be coincident.
 - i
 - 1st of 3 float numbers defining a vector. Only applies when type is set to 0.
 - j
 - 2nd of 3 float numbers defining a vector. Only applies when type is set to 0.
 - k
 - 3rd of 3 float numbers defining a vector. Only applies when type is set to 0.
 - vector
 - HyperMesh Vector entity ID. Only applies when type is set to 1.
 - node1
 - 1st node ID to define a vector in HyperMesh. Only applies when type is set to 2.
 - node2
 - 2nd node ID to define a vector in HyperMesh. Only applies when type is set to 2.
Examples
*CE_ConnectorSetVectorById(1, 1, 0, 0, 0, 3, 0, 0)The connector’s projection vector will be used during the realization process.
