*rigid
Creates a rigid element between two nodes.
*rigid node1 node2 dofs
HyperMesh Tcl Modify Command
- node1
 - The independent node of the element.
 - node2
 - The dependent node of the element.
 - dofs
 - The degrees of freedom for which the element is active (any of the digits 1-6).
To create a rigid element between nodes 100 and 101 in all six degrees of freedom:
*rigid(100,101,123456)
s
None.
