*CE_DetermineConnectionType
Determines the seam connectors' connection type.
*CE_DetermineConnectionType mark_id option
HyperMesh Tcl Modify Command
Determines the seam connection type, such as overlapped, lapped, T joint, and butt joint, and appends the information to connectors as metadata.
mark_id
The mark containing the seam connectors. Valid values are 1 and 2.
option
Reserved for future use. Must be set to 1.
Examples
To determine the connection type for the seam connectors 101, 102, 103:
*createmark connectors 1 101 102 103
*CE_DetermineConnectionType 1 1
   # Handle error
Version History
2021.2
