*CE_GlobalSetString
Set a value to a global string variable.
*CE_GlobalSetString name value
HyperMesh Tcl Modify Command
- name
 - The name of the string variable to set. Currently only g_ce_post_collector_name_setting is supported.
 - value
 - The value of the string. Currently only "use link names" and "use link ids" are supported.
Examples
To set global string variable "g_ce_post_collector_name_setting" to "use link ids":
*CE_GlobalSetString "g_ce_post_collector_name_setting"  "use link ids"
   # Handle error
}Version History
2019
