*rlinkcalcinodeandcreateforcollector
Creates a rigidlink by calculating the independent node based on selection of dependent nodes defined by collector. The supported collectors are comps, mats, assems, props and sets.
*rlinkcalcinodeandcreateforcollector entity_type mark_id dof
HyperMesh Tcl Modify Command
This command creates the rigid link by calculating the independent node based on selection of dependent nodes defined by collector. The supported collectors are comps, mats, assems, props and sets
entity_type
Entity type of collector. Valid entity types are comps, mats, assems, props and sets.
mark_id
Collector put on mark. Valid values are 1 and 2.
dofs
The degree of freedom for which the element is active. Valid values are any of the digits 1-6.
To create a rigid link element by selecting dependent node specified by comps ID 1 and 2 put on a mark 1 with DOF 123456:
*createmark comps 1 1 2
*rlinkcalcinodeandcreateforcollector comps 1 123456
None.
Version History
9.0
