*hmmeshsurfacecone
Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *surfacecone... commands.
*hmmeshsurfacecone quads
HyperMesh Tcl Modify Command
- quads
 - If nonzero, specifies that the created elements should be quads.
This example identifies a cylindrical region of radius 100 and height 200, and then has the automesher create 300 elements on it, with a density of 10 up the side and 30 around the circumference:
*surfacemode 3
*surfaceconefull 180 86 100.0000 100.0000 1.0000 200.0000
*set_meshedgeparams 0 10.0 0 0 0 0 0 0 0
*set_meshedgeparams 1 30.0 0 0 0 0 0 0 0
*set_meshedgeparams 2 10.0 0 0 0 0 0 0 0
*set_meshedgeparams 3 30.0 0 0 0 0 0 0 0
*hmmeshsurfacecone 1
*storemeshtodatabase 0
*ameshclearsurface
None.
