*CE_ConnectorCreateByMark
Creates a certain style of connector at locations specified by a mark, with certain rules and details.
*CE_ConnectorCreateByMark entity_type mark_id ce_style num_links link_entity_type link_mark_id string_array number_of_strings
HyperMesh Tcl Modify Command
- entity_type
 - The entity type that specifies the location to create connectors. Valid values are:
 - mark_id
 - The ID of the mark containing the entities. Valid values are 1 and 2.
 - ce_style
 - The style of connectors to create. Valid values are apply mass, area, bolt, seam, and spot.
 - num_links
 - The number of links to use.
 - link_entity_type
 - The type of entity to create links for. Valid values are:
 - link_mark_id
 - The ID of the mark containing the link entities. Valid values are 1 and 2.
 - string_array
 - The ID of the string array that contains the additional input parameters. The string
            array is created using the *createstringarray command. This should
            always be set to 1. Valid parameters include:
- area_mesh_size=<value>
 - The mesh size for area connectors when using surfs as the location. Default 10.0.
 - area_mesh_type=<value>
 - The mesh type for area connectors when using surfs as the location.
 - area_offset=<value>
 - Offset area connectors created from node or line lists from the selected location by this value. Default 0.0.
 - area_width=<value>
 - Width of area connectors created from node or line lists. Default 1.0.
 - line_density=<value>
 - The density for spot or seam connectors on lines. Default 0.0.
 - line_offset=<value>
 - Offset value from the ends of the line for spot or seam connectors on lines. Default 0.0.
 - line_offset_flag=<value>
 - 0 - Do not offset connectors (default).
 - line_spacing=<value>
 - The spacing for spot or seam connectors on lines. Default 1.0.
 - link_elems_geom=<value>
 - Specifies whether to connect elements (elems) or geometry (geom). Default elems.
 - link_rule=<value>
 - The link rule. Valid values are now, at_fe_realize or none. Default none.
 - relink_rule=<value>
 - The relink rule. Valid values are id, name or none. Default none.
 - seam_area_group=<value>
 - Group flag for seam or area connector.
 - tol=<value>
 - Add entities as links only within this distance of the specified location. Default 0.0.
 - tol_flag=<value>
 - 0 - Do not offset tol (default).
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
*createmark nodes 1 10
*createmark comps 2 3 4
*createstringarray 5 "link_elems_geom=elems" "link_rule=now" "relink_rule=none" "tol_flag=1" "tol=6.0"
*CE_ConnectorCreateByMark nodes 1 spot 2 comps 2 1 5Errors
   # Handle error
