*morphhandlecreatexyz
Creates handle at x,y,z, location for the given system.
*morphhandlecreatexyz dhandletype dmarkhandle domainpointer domainptr name xx yy zz sys
HyperMesh Tcl Modify Command
- dhandletype
 - Handles
 - dmarkhandle
 - Dependent handle mark number.
 - domainptr
 - ID of domain.
 - name
 - Name of handle(s) to be created.
 - xx
 - X coordinate of handle to be created.
 - yy
 - Y coordinate of handle to be created.
 - zz
 - Z coordinate of handle to be created.
 - sys
 - System to create handle in (default = global).
*morphhandlecreatexyz (HANDLES,1,1,"bob",1.0,2.0,3.0,3)
      Handle is created on the specified domain at the x, y, and z coordinates for the given system with dependencies on the handles on the mark. The handle mark may be empty.
The name does not need to be unique since this command will create a unique name for each new handle by adding numbers after the name.
None.
