*readqualitycriteria
Reads quality criteria from the specified criteria file and sets the criteria as current.
*readqualitycriteria file_name
HyperMesh Tcl Modify Command
file_name
The path to the source criteria file (a quoted string ). The file must contain the criteria data in the text format supported by HyperMesh.
To read quality criteria from c:/criteria/durabilty_15.txt:
*readqualitycriteria "c:/criteria/durabilty_15.txt"
None.
Version History
2019.1 - Updated to also read 3D criteria.
