*loadcreatewithsystemonentity
Creates a load (forces, temperature, moment, velocity, acceleration, or constraints) on nodes, fixed points (surface vertices or weld points), surface edges, and surfaces, defined in a local coordinate system.
*loadcreatewithsystemonentity geomtype markmask config type component [1-6] system transformflag
HyperMesh Tcl Modify Command
- geomtype
 - the type of entity that the load is applied to (e.g. SURFS)
 - markmask
 - the entity ID
 - config
 - the load configuration
 - type
 - Solver dependent types of the referenced load config.
 - component[1-6]
 - components of the load being applied.
 - system
 - the ID of the local system to use
 - transformflag
 - Indicates which system supplies component values.
To apply a force of magnitude 10.0 along the x axis of system 4 to nodes 5 and 25:
*createmark(nodes,1) 12 13 14
*loadcreatewithsystemonentity(nodes,1,1,3,0.0,999999.0,0.0,-999999.0,0.0,   -999999.0, 4,0)
      This command is applicable only to files created with HyperMesh 6.0 and higher. For older HyperMesh files, use *loadcreate() instead.
None.
