*elementqualityswapedgenew
Switches the connectivity of the two elements that share the specified edge to the next legal configuration.
*elementqualityswapedgenew element_id edge_index
HyperMesh Tcl Modify Command
This command switches the connectivity of the two elements that share the specified edge to the next legal configuration.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
- element_id
 - The element ID.
 - edge_index
 - The index of the edge to swap, starting from 0.
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualityswapedgenew 27 3
*elementqualityswapedgenew 22 0
*elementqualityswapedgenew 21 2
*elementqualityswapedgenew 26 1
*elementqualityshutdown 1Errors
   # Handle error
}Version History
12.0.110
