*linecreatespline
Create a cubic spline curve by interpolating input points.
*linecreatespline point_type point_list scond econd svector evector
HyperMesh Tcl Modify Command
This command creates a cubic spline curve that interpolates input points. Various conditions can be used to specify the spline behavior at the endpoints.
- point_type
 - Type of entities representing input points. Valid values are nodes or points.
 - point_list
 - List ID of the input points or nodes. Minimum of 2 points or nodes must be selected.
 - scond, econd
 - Parameter specifying the constructed spline behavior at curve start
              (scond) or end (econd). Valid values are:
- 0 - Spline direction at endpoint is not constrained
 - 1 - Spline is closed. In this case any other end condition is ignored. Closed smooth cubic spline is constructed.
 - 2 - Spline direction at endpoint is tangent to direction of input vector svector (for scond) or evector (for econd).
 - 3 - Spline direction at endpoint is normal to direction of input vector svector (for scond) or evector (for econd).
 - 4 - Spline parametric derivative at endpoint equals to input vector svector (for scond) or evector (for econd). Normalized spline parameterization of 0 to 1 is implied.
 - svector
 - Vector used to apply boundary condition specified by parameter scond. Only required when scond is 2, 3 or 4.
 - evector
 - Vector used to apply boundary condition specified by parameter econd. Only required when econd is 2, 3 or 4.
Examples
To create a closed spline that interpolates nodes 11, 12 and 13:
*createlist nodes 1 11 12 13
*linecreatespline nodes 1 1
      To create a spline that interpolates the same nodes, is tangent at its start to vector (0,0,1) and is normal at its end to vector (1,0,0):
*createvector 1 0 0 1
*createvector 2 1 0 0
*linecreatespline nodes 1 2 3 1 2
   # Handle error
}Version History
10.0
