*surfaceaddnodesfixed
Adds meshing fixed points to a mark of surfaces, either by breaking edges or adding interior fixed points. The coordinates of the fixed points are supplied by a list of nodes.
*surfaceaddnodesfixed surfacemark nodelist tolerance createplot
HyperMesh Tcl Modify Command
- surfacemark
 - The ID of the mark containing the surface to modify.
 - nodelist
 - The ID of the list containing the nodes to use.
 - tolerance
 - The closeness tolerance used to decide which points belong to a surface. A point can be added to more than one surface out of the mark.
 - createplot
 - Defines whether or not a plot element will be created between two points. It will be in the ^welds component.
To add a point to surface 190 whose coordinates correspond to those of node 9:
*createmark surfaces 1 190
*createlist nodes 2 9
*surfaceaddnodesfixed 1 2 0.05 1
None.
