*hf_setdiesymmetry
Sets the symmetry plane for the die module.
*hf_setdiesymmetry normal_x normal_y normal_z origin_x origin_y origin_z shape_flag node_1 node_2
HyperMesh Tcl Modify Command
This command sets the symmetry plane for the die module.
- normal_x
 - x-coordinate of the plane normal.
 - normal_y
 - y-coordinate of the plane normal.
 - normal_z
 - z-coordinate of the plane normal.
 - origin_x
 - x-coordinate of the plane origin.
 - origin_y
 - y-coordinate of the plane origin.
 - origin_z
 - z-coordinate of the plane origin.
 - shape_flag
 - A flag that identifies the following cases:
 - node_1
 - First node ID that identifies the portion of the part that is used by the double attached part feature.
 - node_2
 - Second node ID that identifies the portion of the part that is used by the double attached part feature.
To set the symmetry plane z=0 for the die module:
*hf_setdiesymmetry 0. 0. 1. 0. 0. 0. 0 0 0
   # Handle error
}Version History
11.0
