*sethistorylimit
Sets the maximum number of history states to allow.
*sethistorylimit count
HyperMesh Tcl Modify Command
count
The number of history states to allow.
  • 0 - Disables all history recording, including potential legacy use cases.
  • -1 - Indicates unlimited.
To set the maximum number of history steps to allow to 100:
*sethistorylimit 100
   # Handle error
Version History
14.0
