*realizeengineeringentities
Realize engineering entities.
*realizeengineeringentities entity_type mark_id reserved
HyperMesh Tcl Modify Command
entity_type
The type of engineering entities to realize.
mark_id
The ID of the mark containing the engineering entities to realize. Valid values are 1 and 2.
reserved
Reserved for future use. Must be set to 0.
Realize mass entities with IDs 1 and 2:
*createmark masses 1 1 2
*realizeengineeringentities masses 1 0
   # Handle error
Version History
2017.2
