*markcombineelements
Combines selected plate and shell elements into one quad or tria element.
*markcombineelements mark, tolerance quad or tria
HyperMesh Tcl Modify Command
mark
The ID of the mark containing the elements to be combined.
tolerance
The maximum tolerance allowed before a node within the group of selected elements is considered to be not on the plane formed by any three nodes attached to the group of selected elements.
quad or tria
A flag designating the type of element you want to create.
0 - tria
1 - quad
To combine elements 10, 13, and 15 into a tria, using an off-plane tolerance of 0.1:
*createmark(elements, 1) 10 13 15
*markcombineelements(1, 0.1, 0)
This command works with two-dimensional elements only.
None.
